Cletus Van Damme
Previously known as Cheesney Hawks
- Out in the sticks...
I replaced the chain on my commuting bike at the weekend and used it for the first time today and I am having issues that when I stop pedaling if descending or taking a rest the chain often clatters on the chain stay. It is worse when the length of the chain is required to be shorter, for example on the middle front chainring and lower down closer to the small sprocket on the back. I bought this bike used off a mate, so I have no idea if the chain has been changed with the incorrect length. I also believe that this has probably been happening with the old chain but not as bad as I noticed scratches on the chain stay recently, that were not there originally. But I do not think that it was as bad. I measured the chain exactly the same as each other laying against each other and also removed a complete link today by using the method of having the chain around the large front ring and large back. However it is still doing it, not quite as bad but still bad enough. The freewheel appears to be fine and the chain line looks ok and I do not think that the cassette is worn. I have attached a couple of pictures.
What happens when I stop pedalling in certain gears, or try to pedal backwards in same gears:
What it looks like normal in same gear stationery:
Anyway I checked for play in the rear wheel and indeed it has it so the cones are loose. I do not have a cone spanner yet so will not attempt it myself and instead take it to my LBS. Thanks for the great advice as usual
But then again I am not that clued up.
All the more reason why it would be good to be able to maintain them myself I guess.
