Problem with my cycle log signature
Shaun
Founder
The message says you haven't specified a group ID in your signature code; from memory the CC gid is 528.
[Edit: I've manually adjusted your signature code which should update and display properly the next time MCL does and update (they're processed manually so often there's a slight delay for them to appear)].
Cheers,
Shaun :biggrin:
Shaun
Founder
Can you sort mine out too please! I'm suffering the same fate as Pjays666! Thanks.
Your signature code is fine - you'll just need to wait for the MCL guy to do his bit and set-up your account with his service. That part is out of my control. ;)
bainy16
DONCASTER
Fixed for you :thumbsup: You just have to wait for MCL to update.
:thanks:
Pjays666
Pjays666
Burnley lancs
Put a new ride on log couple of hours ago how long does it take to update. I'm not impatient just want to check I've done it right cheers
