Cyclopathic
- Leicester.
I've had the above knocking around for a while. It's seemingly in near perfect condition and looks like it's brand new despite them not being made for about 15 years. I've been dying to put it on something and have tried twice without success.
In both cases when peddling under pressure I get what I would describe as chain slippage. It feels the same as the slippage one gets with a worn chain or worn rear cassette. The first bike I tried to use it on was a mountaqin bike I built up with a Saracen frame and it looked like the nuts. I was very happy until the test ride. I tried adjusting everything and winding the b screw in and out. I changed the chain and cassette together and seperately and the problem remained until I swapped the mech for an acera. After that there were no problems at all and the bike was sweet.
The second bike I tried to use it on was a Birdy folding bike. I was hugely confident it would work as it was almost identical to the one I was removing. That too was an old Shimano rsx long cage. The only very slight difference being the jockey wheel cage was a tiny bit different. Not much and you had to look for it.
Confidebt of sucsess I took it for a test ride and the same again. Again I tried different new chain and different new cassette but again the problem was only solved when I changed the rear mech. This time for a reconditioned Sora 7 speed.
I am at a loss as to what could be wrong with this mech? There seems to be no sense to it and no reason why it should produce chain slippage. I don't think it has ever seen service on a bike as it is so pristine so as I say, I'm lost.
The only thing I've noticed is that the spring on the jockey wheel arm is just a tiny bit stronger than on the one of the other rsx but I put this down to it's not being used.
If anybody can think of what the sweaty hell could be wrong with it I'd be very interested to know.
