I've had a fun afternoon taking a power drill to my hybrid shifters. The rear gear cable had obviously gone inside the shifter, and I couldn't get the cover off because the two screw heads were both really badly corroded. In the end I had to drill the heads off, pull the rest of the screws out with pliers and then find a couple of replacements. I've had a similar problem before with stem face-plate bolts rusting away.
What should I be doing to stop this happening? Or is it just a case of keeping an eye on all the fittings and replacing them before it's too late?
