Presto valve adapter
Willow
Surrey
One of my sons has presto valves. I don't like them much 1) because I'm not used to them 2) because the mini pump I have is obviously not getting enough air into them. I use a foot pump for the other two bikes, is it possible to get an adapter which will mean I can use the foot pump on the presto valves?
MacB
I've got a little brass(looking) screw in adaptor that converts a schrader to presta, 99p at LBS. Got one for both frame pumps and means that I can do either valve type on the go. For home I got the Joe Blow mark II which has a twin headed valve fitting to cover both types.
W
Willow
Surrey
ianrauk said:
this is what you need Willow.
http://cgi.ebay.co.uk/Presta-Metal-...ter-*****_W0QQitemZ270268992056QQcmdZViewItem
If you have a LBS near you, they usually sell them for a couple of £
yep thanks just ordered a couple of another ebay bod for 99p each plus 55p postage.
thank you one and all.
Drilling the rims, god do you know Mr Pig what I'm like with a drill, it would be like a colander by the time I'd finished!
Plax
Wales
I'd go with wot Tynan says. I've got one of those adaptors for my foot pump. Was pretty useless. Got a track pump and it was a revelation. So easy to use and does both my bikes which very considerately have different valve systems.
W
Willow
Surrey
the adapter is great and probably cheapest bike accessorie ever, very hard tyres now bet boy will notice difference tomorrow. thanks all ;)
