Graham1
- The wonderful flat county of Norfolk
I have a problem with a valve leaking when I unscrew the valve to check pressure or to put air in, the valve is fine after I remove gauge or pump the air is p-----g out until you can screw the valve shut, is there anything that can be done to the valve to stop this or do I throw the tube away and get a new one.
