Get a small container of water, rotate your wheel till the valve is at the 12 o'clock position in the frame and dip the valve in the water and look for a tiny stream of microscopic bubbles in the worst case, biggish bubbles are easier to spot. A few drops of washing up liquid in the water will help as then the bubbles will form on top of the water. Just using spit on your valve does not always show up a leaking valve unless it is a biggish leak.
If the valve is leaking and it is a removable one, remove the valve, apply some thread lock and tighten it up with pliers and then check for leaks again.
