LBS (well. mine anyway) has them. I bought a (Kona) bike recently and switched the tubes to Presta so that the valves matched all the other bikes in the family and I didn't have to bugger about with the pump attachment.Landslide said:There is such a thing as a little rubber gromit that you put in the valve hole (with a hole through the middle for the valve stem). Not sure where you can get 'em from though.
