newts
- Isca Dumnoniorum
The non drive side bearing has failed on my Roubaix after 1 year/2k miles, Praxis are saying the bearing isn't covered under warranty.
There are also signs of a flat spot on the drive side of the crank.
Am i expecting too much from a bottom bracket?
Hamibini on youtube gives M30/GXP bottom brackets a right bashing & says most are doomed to failure by it's design & common non drive bearing issues.
Is it 'fit for purpose' & should i be looking for the chainset to be also replaced under warranty?
