thanks,its helped!but not quiet understand,about i have to use 8spd powerlink instead 10spd?is it safest for freewheel and crank system?You can't reuse 10spd links, so a power link is the way to go.
Re-linking a traditional (8spd) chain is quite simple, but not easy; you need to carefully judge the amount you push the pin out, so you can push it back in again. It needs a bit of practice.
May be wrong here but suggest the mention of '10 speed' means 2x 5 speed and this is an 'old' 5 speed chain ie 1/2 x 1/8 (~12.7mm x ~3.2mm).on old Regina(10 speed)chain . . . pin have a d 3,5mm and 8mm length and around 12mm between them(i dont know how its in inch).
hay!May be wrong here but suggest the mention of '10 speed' means 2x 5 speed and this is an 'old' 5 speed chain ie 1/2 x 1/8 (~12.7mm x ~3.2mm).
OP - if this is the case then most of the discussion/comments above are relevant, though @MichaelW2 points the way although it sounds as if you already have a parted chain, assume of the correct length, in which case it's too late to follow his advice - which would hold for a 5-6 speed chain. How many sprockets/cogs are there on the rear wheel?
The 9 and 10 links will not fit. Best idea (and quickest) is to go straight down to your local bike shop and ask for the correct connector for your chain.i ordered 3 different speed (6-7-8;9;10)master link
