Salty seadog
Space Cadet...(3rd Class...)
Hi all, did a 40 miler the other day and I think i may have some play in the BB, a Sram Gxp on a Whyte Montpellier hybrid.
I noticed after a while that the left crank was able to slip ever so slightly if I was not putting full pressure through the peddle (I.e if i just eased of the power for a split second and then reapplied full power) It felt like the crank was catching up on itself and i felt no resistance against the peddle stroke for that split second, so the play seemed rotational. It was at about the horizontal in the peddle stroke with the peddle to the fore. It felt like a slight knock as I reapplied the power.
I later noticed it on the right side crank under the same circumstances.
Gave the cranks a quick wiggle but could not detect any lateral play.
I hope my description is clear enough and welcome any advice/opinions and things to try to diagnose.
Many thanks,
Ssd.
Many thanks,
Ssd.
