Possessed Lightbulbs
Yesterday, I received a number of messages from my daughter about the bathroom lightbulb going bonkers. I wasn't able to reply at the time as I was in meetings, so MrsF had answered.
Turns out the light bulb started flashing when daughter went for a shower. She went to turn it off, and it was actually switched off.
Turned on, light bulb working as normal, switched off, started flashing. Anyway, some time later it stopped.
I explained that LED bulbs, when starting to fail, do weird stuff. The bulb has been in the fitting for some years.
Get home, check fitting, OK, put in new bulb, no weird behaviour.
SpokeyDokey
Spooky things!
T4tomo
Sounds like a loose wire in the switch somewhere (or the switch in out wires in the fitting) in that's its not properly off when it should off and the circuit is being completed.
PapaZita
St. Albans
Agree with the suggestion that leakage could be the cause. LED bulbs have a little power supply circuit inside. A tiny amount of leakage current can cause this to charge gradually up to the point that the bulb is able to light. When the bulb lights there’s not enough current to sustain it, so it goes out again. This repeats causing the flashing.
Particularly since it’s in a bathroom, check for any moisture where it shouldn’t be. e.g, in the switch. We had a roof leak a few years ago that got moisture into the back of a light switch. The LED bulbs in that room went bonkers too.
I'll be checking !
neilrichardson55
Hemel
Agree the lights switch and connections need to be check, it sounds like you could have some power feeding back. bad connection switch or a short somewhere, an led cant switch on its own.
T4tomo
Oooh ....apparently they can, its a real thing and some brands are more prone to it that others see @PapaZita post above or google it
neilrichardson55
Hemel
really.... see its a school day, there must be something in the starter that holds power or static. i know when stormy, tubes used to glow
oh it was stray energy from the neutral makes more sence now :smile:
Tail End Charlie
Well, write it down boy ......
Isn't there something about a switched positive besides a positive can induce enough current to dimly light the LED, or something like that? I only know my outside LED floodlight always glows and someone once said this was the reason.
Bazzer
Setting the controls for the heart of the sun.
+1 for the earlier suggestions of checking circuits.
On our landing we have some of the early GU10 LEDs. - Which didn't have a bypass capacitor fitted. So even with the switch off, they glow at night from the quiescent current.
Remarkably handy for nighttime bathroom visits, but could be spooky for anyone not used to them.
