Pop rivets for fixing a head badge
Banjo
Fuelled with Jelly Babies
South Wales
I dont know but wonder if pop rivets would be a good idea at all. The hole would allow water in. I think I would consider glueing it on with epoxy or sikaflex or similar.
porteous
porteous
Malvern
Argos cycles (Bristol, not your local catalogue store) use tiny pop rivets. Given Argos' reputation for fine work I think PRs should be OkK
I will fill the hole with devcon. Finding the brass rivets is almost impossible then you have to peen them from inside.)
grumpyoldgit
Surrey
There is a type of rivet some makers used,domed head,twisted splines on the shaft.These just tapped in,cant remember the name of them,even got a few somewhere.
