[QUOTE 1732436, member: 9609"]In the case of a cyclecomputer and its cradle where they are regularly separated, would grease not make the connection even worse?
Is Silicon grease not a poor conductor and is usually used to smear on the outside of permanent electrical connections and acts as sealant to stop the ingress of water.[/quote]
To be sure of my answer I have tested some silicone grease on my own cycle computer this afternoon and it does work.
You are correct that it does not conduct electricity but being a thin grease it doesn't prevent the contacts from touching each other it also (in theory) shouldn't dry out like normal grease.
I should have put some on ages ago. I no longer have to wiggle the computer before it'll work at the start of a ride.
