Hi guys
I have the Shimano Ultegra R8100 crankset. I am not sure if the Shimano Ultegra PD-R8000 pedals I intend to buy fit the cranks. Please help.
Thanks.
Easy way of remembering is that both sides screw in towards the front wheel and unscrew towards the rear wheel. Put some grease or copper slip on the threads and don't overtighten.
There are 2 sizes of pedal thread, 9/16ths and 1/2 inch (apart from weird French stuff in the 40-50's) 1/2 inch is generally BMX while everthing else is 9/16th
Is this the first time going clipless?
Shimano pedals seem a bit pricey, worth considering other shimano compatible pedals or even looking (unintentional pun) at Keo pedals.
You can get reasonable pedal+cleat sets from £40 upwards.
