Please help me choose the right inner tube
Basementcat
I'm a bit clueless when it comes to inner tubes and the sizings. I've went through 3 different inner tubes since my most recent punture and I'm not taking the chance of getting the wrong size again. My tyre is a
700x35C Schwalbe Silento
Please help me! đŸ˜…
Spiderweb
Not So Special One
North Yorkshire
What valve do you have Schrader (like a car) or Presta?
Spiderweb
Not So Special One
North Yorkshire
If it’s a Presta Valve then try these 700c x 28-35mm
https://www.planetx.co.uk/i/q/TUVAV700/vavert-700c-inner-tube
507639
13 rider
leicester
507645
Presta valve ,if it doesn't look like this it's a Schrader.
Another variable is the value length but normally this only matters on deep section wheels but if your tyre is 38mm wide I doubt it's a deep section .
I rate Halford tubes
Deleted member 26715
Curve ball, if you don't want as many punctures consider slime filled tubes.
