Play in bottom bracket
Cycleops
Accra, Ghana
That’s a lot of play. Is it a Hollowtech or pressfit bottom bracket? If it’s Hollowtech it’s a simple replacement for around £15 if it is just the bearings. If it’s pressfit it may be a more complex problem and you won’t know until you remove it.
Cycleops
Accra, Ghana
You're going to need some tools to remove and refit unless you make some. YouTube is your friend. The replacement bearings need to go in square so you'll need to make up a press with some threaded stock, bolts and washers. Tap them out evenly with a wide end steel bar. Otherwise it's a special tool.
J
Jimmy Welch
Yes Ive seen the videos of press fit out and press fit it , my own bikes is aware taper peice of cake , but the press fit looks like something from the Spanish Inquisition best take it the LBS , take it there's no quick hack , tightening a bolt there or , spray wd40 here etc ?
  • Like
Reactions: C R
Roseland triker
Cheese ..... It's all about the cheese
By the sea
If you heat it up it will get tight. Then bash it with a hammer while pouring iced coffee on it .
When it shrinks as you bash it the iced coffee holds it in tight again.:crazy:
Cycleops
Accra, Ghana
Once the bearings have gone that's it, you need to replace them. There no quick fix.
Press fit was pioneered by Cannondale who one day sat down down with the devil and agreed to sell their soul for a new cheaper easier BB system. This was the result.
I should take it to your LBS for the repair, given the problems you might have with the replacement like squeaking. I'm sure you want to remain mates with your friend 😉
  • Like
Reactions: C R
Twilkes
When it works properly, pressfit bottom brackets can be the best performers from a weight and stiffness point of view, it's just that they quite often don't work properly. :smile: This is usually due to loose manufacturing tolerances and errors when installing.
@Jimmy Welch I have the pressfit tools you'll need if you want to give it a go yourself, can pass them on for a couple of quid, my BB30 bike got nicked unfortunately. It's very rewarding to do stuff like this and not really difficult, and if you take it steady you can sometimes do a better job than an LBS who might cut corners and leave you with problems further down the line.
Edit - actually, maybe not if it's not your own bike, I've rarely had a positive experience trying to fix stuff on other people's rides!
J
Jimmy Welch
That's dam decent of you , this is my pals bike , mines a square taper so I've got the tools , and if I don't get it right and it's a carbon frame and I don't have many mates , I don't want to loose another , but that's really very kind of you , but it's a one off so I'll let the LBS take the strain on this one
Twilkes
Yeah I'd already edited my post to imply that. :smile: I'd always encourage people to maintain their own bikes though, even if it means buying tools, once you understand how things work bikes are actually quite straightforward to fix.
