Planet X stealth pro carbon
Andythegwarve
hello,
I've just bought a stealth pro carbon frame and looking to have a stab at building the bike up. I first need to buy the rest of it. Any idea what the bottom bracket on one of these is? I can then look at a bottom bracket to buy and a crank set to fit. I'm new to all this bike building side of things but felt like giving it a go. Thanks .
Citius
The BB is standard BSA threaded, so Shimano HT2, or SRAM GXP, or FSA MegaExo, or similar. Or even square taper...
I always find it easiest to follow the spec used by the manufacturer of the full bike. Look at the PX site
Are you going SRAM or shimano for the groupset?
Cubist
Still wavin'
Ovver 'thill
What the website won't tell you is things like cable routing, headset spec for the fork,front mech mount options. For example I got a Pro Carbon frame and then had to set about finding threaded cable guide adjusters, BB mounted cable guide, different length brake mounting nuts..... Not an endless list, but you need to find the right diameter seat post and clamp, and know the standards for the headset etc. . As for groupset, well, the world is your oyster
I didn't have a problem finding all the correct measurements for those parts for my Genesis, for some of them I just sourced the exact same part, like the headset and the brakes from memory. Perhaps planet x aren't so diligent. You could always call them and ask of course :smile:
