Pedals
ScotiaLass
Middle Earth
I want to replace the pedals on my Specialized which is currently sporting the stock plastic thingies.
I want the same flat pedals, just not plastic.
Any recommendations? Also, how easy are they to replace?
MissTillyFlop
Evil communist dictator, lover of gerbils & Pope.
You need a pedal wrench and it might take a little bit of effort physically but it is pretty easy. Also some grease on the new pedals will be required.
There are lots of great metal pedals. I prefer clipless and I used to have a pair that were clipless on side and regular pedals on the other side.
These ones: http://www.wigglestatic.com/product-media/5360031862/Shimano PD A530a.jpg?w=2000&h=2000&a=7
http://www.wiggle.co.uk/shimano-a530-spd-single-sided-touring-pedals/
BTW, I want to ride my bicycle is on the radio as I write this - co-incidence?
MikeG
Suffolk
You may not need the thin pedal spanner that MissTF mentioned, because lots of pedals these days have a hex key alternative. You'll just need a fairly hefty hex key or multi-tool. Don't forget that there is a left and right pedal, and that one of them screws up on a reverse thread (ie if you turn it anti-clockwise, it does up tighter). A dab of vaseline on the threads before you put the new pedals on will make them easier to remove when you eventually upgrade to clipless (!!! :smile: Why haven't you done this yet? :smile: ). Changing pedals is a dead easy 5 minute job, so long as the old ones aren't done up too tightly.
Mike
ScotiaLass
ScotiaLass
Middle Earth
Mike
It's a new bike and only been ridden for 4 miles (damn weather!).
I won't ever go clipless as I have balance issues and need to be able to put both feet on the ground very quickly....I feel safer knowing I can just take my feet off the pedals if needed!
Thanks for the advice :smile:
MikeW-71
Carlisle
Looks just the job :thumbsup:
Cubist
Still wavin'
Ovver 'thill
I suspect you are unlikely ever to want anything more than the DMR V8 recommended above, unless you want some bling colours. (V8 lose their colour pretty quickly unless you go for the plain silver ones).
That's not to say that there aren't some nice pedals out there for little money. Check eBay for V8 copies by Wellgo, still pretty good, or for some groovy shapes and colours look at Superstar components, Nukeproof, even Bikehut.
For engineered beauty, try Shimano Saints, currently on offer on various mail order sites. If you decide to run pinned flats, remove the middle front pin, that's the one that rips yer shins.
I like Skol
A Minging Manc...
i use the wellgo copies, they've served me well for a good ten years, and my foot has never not once ever slipped off them :thumbsup:
Just received and fitted a pair of these to my oldsest son's bike today. First impression is that they are a great budget pedal. I forced grease into them by removing the dust cap and using my thumb to press the grease in until it came out of the axle seal so no worries that they are dry/undergreased. They seem to offer a great platform with the grippy pins as a bonus. I'm sure Jnr will gouge his shin at some point in the summer when riding in shorts :wacko:
Gravity Aided
Land of Lincoln
ScotiaLass
ScotiaLass
Middle Earth
