Amanda P
- York. Well, York-ish...
I know that bog-standard pedal threads are 9/16", 20 tpi, but is that BSP or BSF?
I'm asking because an engineering friend is making up a set of short cranks (for the diminutive Mrs Uncle Phi's use) by boring out and cutting down a regular set. Boring the holes for the pedal holes is tricky because they have be exactly parallel to the bottom bracket axis, and then the thread has to be cut perfectly square too. He's going to do some clever stuff with lathes and pillar drills to get everything lined up.
Then we need to get some taps. I'd just get Park Tool ones, which presumably will be the right kind of thread, but he uses a more general supplier from whom he can get discounts, being in the trade, and they don't sell these taps as specific bike tools but just general engineering stuff.
So, any of you engineering types know - quick as you like - BSP or BSF? Or is it a silly question?
