Pedal fitting
boybiker
In a word no but it would be better than nothing as a temporary measure. Grease will keep the tread lubricated for a lot longer as it won't fling off after 3 mins!
youngoldbloke
It will do, but a small tube of Copper Grease will last for ages, and can be used wherever you need anti seize - e.g. bottle cage bolts.
edit: £2.19, lasts forever. Also use it on cleat bolts. Invaluable!
ianrauk
Tattooed Beat Messiah
Rides Ti2
Any grease will do.
I have used cheapo halfords for many years on pedals and they have always undone easy enough.
Don't use GT or WD40 as they are water displacers.
compo
Harlow
I have a tube of copper grease in my toolbox that must be 20 years old and is still only half used. As has been stated, a smear is all that is required on the treads. For normal use I use standard lithium grease from the local agricultural merchant. Again, a tub will last years.
I would like to know what the name of the grease new bikes have on the bearings, the blue or green stuff. Undisturbed it stays good for years.
