Ghinwha
Member
- Derry City Northern Ireland
Hello everyone. I’m having a little nightmare with a Pashley Sovereign Roadster 5 speed I’ve bought second hand off Gumtree. It’s over 10 years old but I can’t seem to get the gears set up properly. It either slips in third on the flat and when I adjust the yellow marker around to it’s factory recommended position to fix that it then slips in first when I hit any gradient at all. It’s running Sturmey Archer 5 Speed X-RD5 (W) sa hub with a Yellow Indicator Rod marking. I think Its the SL50 shifter which doesn’t seem to pull back to the detent positions under pressure from the spring in the hub when moving down the gears from 5th to 1st. I do click it in manually of course when riding and I also make sure it’s in when lining up the mark. I put a brand new cable on and am talking about a hub rebuild. Pashley have said that at over 10 years old it’s likely shot. Love the bike and this is spoiling the craic, any recommendations or experience of this? Thanks in advance
