For reasons outlined in this thread, I have two wheels I'd like to butcher into one. Both are 700c, 36-spoke, 26mm outside width and apparently similar rim depth. Both are running hubs with a 44mm spoke PCD, with an approximate spoke length from the spoke elbow centre in hub to the ID of the rim of 295mm. They are:
1. Chromed steel Raleigh wheel with 5-speed freehub on 120mm axle spacing. 2.05mm OD spokes, 3.2mm AF nipples with 3.8mm OD.
2. Ally BSO wheel with 6-speed freehub on 126mm axle spacing. 2.0mm OD spokes, 3.4mm AF nipples with (apparently) 3.8mm OD.
Due to various bits being knackered I want to rebuild the good bits into one wheel consisting of No.2's ally rim and No.1's hub. I'd prefer to use the nipples from No.1 as they seem like a more common size, are in better nick, likely better quality and I have a key to fit them. Jury's out on which spokes to use - No.1's are far older and one has snapped (so I'd have to use at least one from No.2) while No.2's are complete but potentially manky quality steel.
Can anyone suggest any reasons why this shouldn't work? While some parts aren't identical, I can't see the differences causing any problems.
Answers on a postcard please - maybe by the time it gets here I'll have got my arse into gear
