Parts Bin Road Bike
MahatmaAndhi
Peterborough, UK
Hi all,
I've got some stuff lying around that I've accumulated over the years. And I was wondering if they'd be compatible.
Long story short, would a Claris front derailleur work with a Tiagra crankset? I can't see why it wouldn't, assuming both are double/triple speed (I can't remember and it's too wet to go digging around to check).
I have the compatible bottom bracket for the Tiagra, so that's covered. Anything else?
I think the frame is an old steel Raleigh Pulsar. I have some 700c wheels which are fine for a cassette, spare Tektro long-cantilever brakes (which may or may not work straight off the bat), Claris brifters and rear derailleur and an 8-speed cassette. I also have better shaped handlebars. As far as I can tell, I will need to cold-set the frame and also get some bosses (correct term?) to put on the downtube where the shifters used to be.
Thanks
Cycleops
Accra, Ghana
Should work fine, you'll soon discover if they don't.
