~Start with rust stop, then a dilute primer, then sand it down,  then  full on primer, then sand it down, then another coat of primer, then sand it down lightly, then undercoat, sand it down to primer coat, then undercoat, then sand it down lightly, then second undercoat, then sand it down lightly, then base top coat, sand it back to under coat, then first top coat, then sand it lightly, then second top coat, then lacquer x 2 coats.
Or  start with rust stop, then spray coat a primer and sand down lightly, then spray coat a second coat of primer, then undercoat and finally a top coat followed by 2 x lacquer. both will end up (if done properly) looking like glass. one is a lot less work, and quicker.
