P-clips - Where do they go?
Matthew_T
"Young and Ex-whippet"
Are they for the seat stays or where the bosses should be? They come in all sorts of sizes and styles and I just wanted to know if it really mattered where they went.
They position relative to where they are needed. They're different sizes due to different tube dimensions. So they go at the tops of the seat stays for racks, bottom for lower rack fixings and guards :thumbsup:
I can't find a great picture, but this gives you an idea
guitarpete247
Just about surviving
Leicestershire
It depends what you are wanting to attach. If you don't have bosses for rack or mudguards, put them where you need them.
At least that would be my opinion.
jim55
glasgow
60 mm diameter !!!!thats the seat tube is it not ?p clips for a rack gen attach to the seat stays and they are about 12 mm ,you sure your measuring the right bit /the right way ,,
e-rider
Banned member
South West
My tube diameter is 60mm. I have found some p-clips to fit this but they are very expensive. Where are the cheapest ones?
60mm? I think that part of the bike is known as the tyre!
Matthew_T
Matthew_T
It is the part shown in the picture above. I have measured it with a tape measure and it comes out at 6cm or 60mm.
It is the circumference. It does seem like a large number compared to what I can find online. My seat stays are 10mm.
I am doing something wrong. Someone help.
Matthew_T
Matthew_T
I have just realised. The clips are refering to diameter, not circumference. Therefore a 60mm circumference is going to be a 19mm diameter. Should I go up or down as the clips only come in either 18 or 20mm?
Overconfidentii Vulgaris
Up. The 18mm will be too tight. If the 20mm clip is too big (which I doubt) it's easy to pad it out with a bit of old inner tube.
Personally, I used 21mm stainless ones from a marine chandlery which I found a better fit than the sort stocked by most bike shops.
Matthew_T
Matthew_T
I have accurately measured it and it is 20mm so I think I will get that size. If they are too small, then I can always send them back and get an exchange for a bigger size.
