robjh
- Cambridgeshire - almost Essex
I've just put a new Mavic Open Pro C (700c, 32 hole) rim on a front wheel to replace an older buckled one, reusing the same hub and spokes.
I've done this before (on other wheels) using Open Pros a few times with no great problems.
I got the wheel pretty much true and round to my satisfaction, but then noticed faint marks on the rim on either side of some eyelets that turned out to be slight deformations, or raised areas, in the surface.
They are just about visible as white areas to the R and L of the eyelet in this photo:
My first thought was that I'd seriously overtensioned the spokes, so I loosened everything off by half a turn and retrued the wheel, which wasn't hard.
The spokes don't feel exceptionally tight to the touch now - there is some give in them if I grab neighbouring pairs - and the ping tone is not crazily high to my ear, but I have no tension meter to prove anything definitively.
So my questions are more or less:
- is this rim damage caused by over-tight spokes?
- can I do anything about it now it's happened?
- should I worry?
Thanks for any thoughts on this.
- should I worry?
