So my rear wheel wasn't spinning as well as it should coming to a premature halt and made a slight grate noise. I took the cassette off (very first time) and removed the lock nut to gain access to the bearings, gave them a bit of a service and went to put it back together.
I did everything backwards but when I put the wheel on the bike it would not spin- not freewheel or pedal around, so whipped it off again and loosened the lock nut on the hub a half turn and it spun a bit, another half turn of lock nut and it's fine, spins lovely, all seems to work.
Does this sound normal? should the lock nut not be done up too tight?
I've never ventured into the world of cassettes/ hubs etc. so will happily swallow my pride and drop it at the LBS for them to fix if that's what it needs!
