Ajax Bay
- East Devon
I have a band-on front derailleur (Shimano FD-6603 triple) which I plan/hope to use on a new build. It is marked as 31.8mm and the new (to me) frame's seat tube is 31.8mm OD (on seatpost clamp and measured). But the band is not 'round': it's below 31mm on one diameter and above 32mm on the diameter at right angles.
I used the derailleur with a shim (but not a metal one - mistake) on a 28.6mm seat tube (for maybe a year/10,000km) and I assume that sufficient tightening to keep it in place bent the hinged part (hence the reduced diameter). It's alloy (assume Al mainly). Image below is a new one (not mine).
I seek advice on how best to return the band physically to its circular design. Doesn't need to 'move' far so I think that work-hardening is not a threat.
http://media.canyon.com/download/manuals/Manual_FD_6600_EN.pdf
