oval chainrings
David_widnes
Widnes
Hello,
has anybody got any information on oval chainrings im thinking about giving them a try but i would like some opinions before i jump right in and buy.
Im think of putting them on my Specialized sirrus pro
any feedback will be gratefully received.
cheers
Herzog
Swinglish Mountain Goat
I believe they're supposed to increase power delivery during the downstroke. Not sure how much this would benefit normal-level riders...
rockyraccoon
It does improve power but also saves much more energy. I've never tried it but everywhere I read about them they are well recommended. Apparently you can see great improvement in your efficiency right after making the switch. If u can't improve you pedal technique (which can take ages of dedicated training) then the oval chainring is a good option. However if u are not racing I can't see the need for it.
TheDoctor
The TerrorVortex
It's one of those ideas that comes and goes every 20 years or so.
I can't see the point - the only people I've ever known to rave about them are those selling them.
Not that I'd try and put you off at all...
TheCharityShop
The wheel has been in existence for thousands of years and is the most efficient means to move anything about
Oval chainrings are utter gimmicky nonsence, supposedly more power on the downstroke but surely negated on the upstroke?
DONT MESS WITH THE WHEEL!!
My Muddy Fox Courier had ovalised chainrings, circa 1986.
Sleeping Menace
UK
The Rotor Qrings work very well. I didn't have much faith in the concept till I used them a few times on a friends bike and actually found them worthwhile.
Like anything, the results will vary person to person, but my own impression is that vs making me immediately faster, they allow me to go fast for longer without the fatigue.
They're very much worth going for and work much better than some of the earlier efforts...
I did a mini-review of them on my blog if you're bored.. :
Q rings 5 min review
http://anotherdooratthe.endoftheinternet.org
Cycle related blog entries, including a few 5 minute reviews:
http://anotherdooratthe.endoftheinternet.org/category/cycling/
byegad
NE England
I think they're gimmick. It doesn't help that Egg rings and Q rings are set at around 90 degrees to each other and both are an 'improvement' on round rings!
Bicycle
You'll think they're great...
Then one day you'll wake up and say to yourself "I need to build myself a full-on, high-fashion fixie to optimise my full-on enjoyment of this excellent cycling life in the city I am so proud to call my home".
But you will be unable to render your wonderful steed into a fixie, because that stuff doesn't work right with an oval chainring.
So don't do it.
It will shatter your dreams at their very core and turn the daylight of your waking soul to darkest night.
Unless you're unlikely ever to want to go for a fixed-gear bicycle that is....
In which case, why not?
sunnyjim
Edinburgh
So don't do it.
I think it does work - half the teeth on the chainring is always the same number of chain links. The change in angle between sprocket & chainring is prolly negligible.
Not that I'm about to try.
What next ? oval tubes ?
