cool_hand
I have an old Genesis Aether road bike that I use primarily for shopping/post-office runs. The levers are Shimano Sora ST-2300. Unfortunately the left-hand lever took a knock and cracked last week so I'm having to replace. The schematic for the lever and the bars are fitted with an Outer Cable Guide (Y-86B-90010) - a triangular plastic snake like housing that sits under the bar tape and holds the brake cables in place. I've never seen these used elsewhere and I can say the triangular shape is that comfortable under my fingers. I can still use what's there but I looked for this as a replacement part and it's pretty much thin on the ground so is clearly not popular. Should I just remove the cable guides all-together and be done with them? Just tape the cables in position and then cover with bar tape? Or is there a specific reason why the ST-2300 levers use the guide?
