Rhythm Thief
- Ross on Wye
... I've broken my girlfriend's car.
By not checking the antifreeze.
It wouldn't start on Tuesday morning, so we bought a battery, which I fitted. Still nothing, so I took the distributor cap off and was horrified by the state of it, so I changed that, and the HT leads and plugs, and checked the spark. Still nothing, so I checked the fuel supply and tried starting it by pouring fuel directly into the throttle body. I took the rocker cover off and checked the valves and camshaft. Finally I checked the compression (as I was running out of ideas at this point) and discovered it was about 20 psi on cylinders 2 and 3. Oh dear. I assume it's frozen as it failed very suddenly , and the fact that it's two cylinders next to each other indicates to me that the block has cracked. So ... (irrelevant to bicycles, I know) ... CHECK YOUR ANTIFREEZE!
