Online banner seems to have gone a bit odd
ttcycle
Cycling Excusiast
Hi guys
Just posting up here - the online banner seems to have spaced the e off the online onto the following line so it's now wider.
Possible bug?
Shaun
Founder
Hi tt,
The wording is text based so if you increase the text size (or zoom in) with your browser it fluffs up the layout and wraps the 'e' (and possibly more of the letters).
If you're on a PC based browser hold down the CTRL key and then press + and - on the number pad of your keyboard and you'll see the web page increase and decrease in size.
The next thing to do is hold down CTRL and press the zero number key - which resets the view to 100% - and which, should, return the formatting of "Online" back to normal.
If that doesn't work, let me know and I'll look at maybe changing it for something simpler that won't go "wonky" when viewed at different zoom levels. Maybe a little green dot in the corner or something. I don't know, we'll see. :thumbsup:
Cheers,
Shaun :biggrin:
ttcycle
ttcycle
Cycling Excusiast
ah yes - that makes perfect sense - I thought my settings were back to normal but clearly not.
Thanks!
Shaun
Founder
I've now modified the online marker so it's a small graphic at the top left - it should now resize without breaking out of its placeholder!! :thumbsup:
ttcycle
ttcycle
Cycling Excusiast
I just noticed that- that's great thanks!
Completely unrelated but for some reason I'm trying to send a photo in a private conversation and it keeps stating that the file size is too large- the smallest I can get the file is down to circa 800mb. Any ideas Shaun?
Shaun
Founder
800MB? :eek: The file limit for personal conversations should be the same as the forums - 2MB. :thumbsup:
ttcycle
ttcycle
Cycling Excusiast
not mb sorry just 800k.
So it should be attaching then?
ttcycle
ttcycle
Cycling Excusiast
I'm just uploading it as a standard file from my desktop however it's failing each time.
Shaun
Founder
What's the file extension though? (Some are allowed, others aren't!! :thumbsup:)
Also, could you please email me a copy of the file (providing there's no privacy issue) and I'll see if I can upload it in a conversation with you?
shaun ... dslsjdlksjds ... @cyclechat ... sljlksdflaskjd ... .net :smile:
Cheers,
Shaun :biggrin:
Shaun
Founder
Sorted. The dimensions of the image were too big for the XF software to safely resize. Manual resizing did the trick. :thumbsup:
Hi guys
Possible bug?
Are you talking about the 'online' banner on your name?
If so the solution doesn't work, everyone's name is partially obscured by the small banner indicating they are 'online'
I am on FF10 BTW
