StrongEagle
Old guy wearing out his knees!
- Houston, Texas
I think I know what happened, and, I lay this problem out before the experts.
I was riding in Brazos Bend State Park today (Needville, Texas). Made about 11 miles and then I got a flat front tire. I had to push my bike back to the car... fortunately, only a little bit more than a mile. I figured that I got a puncture from a thorn, or maybe one of those tiny triangular pieces of silica that do a fine job of piercing the tire just enough to let out the air.
So... this picture shows the type of surface I was riding on... and a gator that I had to pass. It's mostly packed down pea gravel with forest trail. It had rained just a couple of days earlier, and while it was mostly dry, rolling resistance was much higher, sometimes even having to peddle through muddy spots. Mostly, I had to shift down at least one gear from what I normally use.
So... I walked my mile plus back to the car and headed home. I checked the tube when I got home, looking for the leak, using a water bath, and expecting to find a puncture somewhere that would help me find the spot in the tire. So... I'm looking for a little bubble stream coming out of the tube. Instead, the video shows what I found. Enough bubbles to make Thunderball look shabby. My tube would make a good aquarium aerator.
https://1drv.ms/v/s!Ai1qoBekoDRPhcJe0OpVFGhoQoCzcw?e=ZpyEu4
I can't figure this out. I think I found one single place in the tire where a puncture might have occurred. It sort of looks like a thorn went through the tire, then pulled back out. I don't think I rode on the flat... I mean... rolling resistance goes up big time... especially when riding on gravel/dirt surface, which I was doing. And... no alcohol or doobies, thank you.
So... how come I have so many leaks in my tube? Did it happen from walking the bike back to the car? I'm thinking of buying puncture resistant tires for my next tires. Any recommendations? I'm currently running Kenda 622-40's.
Thank you for any thoughts or advice.
