Georgina in Egypt
- El Gouna, Red Sea Coast, Egypt
Went for a lovely bicycle ride this morning before the temperature exceeded 35 degrees.
Had to turn round because my back tyre was soft, and limped to the bike shop which was closed.
Just dragged the bike up to my 2nd floor apartment for closer inspection and there is black gunge dripping from inside the tyre.
I have a slime inner tube in the back tyre and the valve has moved round so pointing out at an angle. Tried to inflate the tyre but succeeded in letting out the remaining air instead.
My question is - should I take it to the 'Egyptian' bike shop where they will attempt to removed the tyre with large spanners and put an ordinary tube inside. My tyre is split so if I am lucky, and they have a spare tyre, that will need changing (last time they took a tyre off a new bike!).
Or should I do it myself and clean up the mess (will that be easy?) and put the only one other slime tube I have back inside (unable to get more unless some kind person brings one out from the UK).
Grateful for any advice
