Jacomus-rides-Gen
- Guildford / London
I have just knocked Gen off the repair stand
Her landing was cushioned by the mech hanger, which unsurprisingly bent. Using a bit of brute force I bent it back, but now it has telltale flaked paint.
The aluminium under the paint doesn't appear cracked, but I am aware that it is compromised now. My question is - how much load does the mech hanger have to take?
Even at full power is there much load on the rear derailleur? It seems to me that the top run of the chain, thus the chainrings and cassette are heavily loaded, but the derailleur just keeps the bottom chain run from flapping around.
I don't have the money to buy a new hanger this month, and am wondering if it will suddenly and disasterously snap 50km into a club run.
) when you change up and down the gears thus moving the rear mech. You are pulling the mech obviously and the force is distributed through the mech to the hanger - the over all surface area of the joint between the hanger and the frame dissipates this force in to the frame, this force distribution is also helped by the joints and springs of the rear mech soaking it up some what. Assuming that you really haven't cracked the frame you should be ok. Having said that you are right that you have compromised the material integrity of the aluminium but to what extent you'll never know.
! It might have been because he'd bent the hanger over too far causing it to go into the spokes when he changed to bottom gear, or perhaps the hanger had snapped first and everything else happened as a consequence of that?
