TechnoTim2011
I have been lent a bike, it is apparantly a Raleigh M-TRAX mountain bike of late 1990's vintage. The deal is that I fix the lendors Apple Mac G5 in return. But the bike needed some TLC.
Degreasing cleaning and reindexing the gears was straightforward. But the brakes were odd.
We took both front and back V-brakes off the cables were all in good nick but these are unlike any V-brakes I have seen before. there is no tension adjustment screw and the tension spring sits in a kind of lug that does not locate in any of the holes in the braze-on fittings on the frame.
Photo from this angle and from this angle
and
from another angle
The only way tension it is to get an adjustable wrench and hold the lug (angled downwards on the photos) at an angle and tighten the brake actually slides on. But getting both sides the same seems to be impossible, symmetrical doesn't work and because it springs back wen the allen screw in the centre of the brake pivot is released it seems to be all luck rather than judgement.
I am going to replace this brake system with shimano acera when funds allow, but right now I want to ajust them properly.
Can anyone point to a service manual/howto/tutorial or otherwise advise.
and
from another angle
