Odd problem on almost new wheels
CharlieB
Junior Walker and the Allstars
I recently upgraded the wheels on one of my commuter bikes to a pair of Mavic Crossrides for summer use. They weren't wildly expensive but riding home the other evening, suddenly the brakes on the rear wheel made a 'per-revolution' noise.
On closer investigation in daylight, the braking surface has developed a tiny nodule of metal that is obviously causing the problem. It's not on the outer edge of the rim, so I doubt it's pothole damage - it's right in the central area of the braking surface.
These wheels have done less than 250 miles in five weeks - do I just file the little nodule down, return the wheel under warranty, or just wait for it to wear down in its own time?
MacB
Weird, have you verified it's not something embedded that's giving the impression of being a protrusion? otherwise I'd return under warranty, I wouldn't want to file down and trust to luck.
Fnaar
Smutmaster General
Thumberland
I've had those on my back wheel... a friend (who knows far more than me about cycling and stuff) said they were little impurities in the metal... and just sandpaper them off lightly. Worked for me.
I have always presumed that these were caused bits of debris working onto the brake pad and then kicking up a bit of the rim when the brakes are applied.
As above, I just get some very fine sandpaper and level the surface off.
I'd check the pads for embedded metal fragments as well.
zexel
Cambs
Is it directly opposite to the valve hole?
