philepo
Notes on lubrication for internal hub bicycle gears
You’ll have to google centi stokes (cSt) and centi poise (cP) and how to convert them! J.
Basically there are 2 issues looking at viscosity: 1 a lot of manufacturers state viscosity at 40 C or the use cP and cSt, which are different depending on density (i.e. water is 1 cP and 1 cSt because it has sp gravity of 1 at room temp). Its hard to find consistent measuring techniques for viscosity, e.g. temp, cP or cSt etc. For the engine oil viscosities I have aimed to read them off at 10 to 20 C, not 40 C as is standard. Also, remember that grease is thick due to thickeners, not because it is viscous per se. I mean you can have a thick grease that's made from a thin base oil... The grease is made to keep the base oil near the bearing, not to 'be thick oil', if you get me.
Anyway, my fascinating (!) story on hub gear lubrication:
The old Sturmey Archer (SA) literature used to suggest using a few drops of oil (via the oil port on the outside of the hub) every few weeks and they used to say SAE 20 or similar. Since the late 90s oil ports to top up the hub oil are no longer present and instead they are filled with a semi-fluid grease (grade #00) from new and the maintenance instructions basically say they are either maintenance free or that they need ‘repacking’ occasionally.
There are many web forums discussing oil vs grease and so on, and based on my research this is my interpretation of the evidence plus some of my own opinions based on technical facts.
My personal experience:
The logic I think drove hub gear manufacturers including SA to change to grease was:
Based on all that, my suggestions for grease filled hub gears are:
Hope you enjoyed that
- SA used to state adding a few drops of SAE20 every few weeks
- SAE20 has a viscosity of ~200 cP at normal running temperature (i.e. 10 to 20 C, not 40 C)
- SAE20 is hard to find but SAE 20W50 is a common car engine oil for older engines and is easy to find – note 20W is its weight when cold… which it will be in a hub
- SAE20 or 20W oil should ideally not have detergents in it as it is best for debris to fall out of suspension and not circulate. However, these detergents tend to be designed for hot engine oil in an engine so may play no role at room temperature
- Engine oil tends to have lots of nasty chemicals and metal compounds in it and is bad for the skin and smells unpleasant so if possible, find a non detergent oil
- Gear oil of SAE80 is equivalent in viscosity to SAE20 crank oil (the scales are different) and so this can be used, but again is has lots of nasty additives and really pongs!
- Popular cycle oil, e.g. Weldite TF2 has a rated viscosity of 20 cP (temp not stated but presumed to be lab temp @20 C). The ‘extreme wet’ version of this has viscosity of 62 cSt at 40 C… so maybe 100 cP at room temp perhaps?
- GT85 has viscosity or 11 cP (again, temp not stated but I’d presume lab temp of 20 C). This is 16 cSt after density converted.
- These oils may be ok for general tasks where the capillary action is desirable in order to reach bearing surfaces but is 10 to 20 times too low for hub gears (i.e. SAE20 oil recommended by 1950s SA was ~200 cp)
- Note that grease of grade #00 has a viscosity of ~500 cp, so 2 to 3 times the SAE20
- Note that the latest SA data sheet I could find for my own 5 speed sprinter hub stated that SAE30 oil should be used. I went to the local shop and bought 30 weight lawn mower engine oil
- I stripped the old grease out (it was sparkling with metal debris) thoroughly cleaned and rebuilt with a very generous application of SAE30 oil (also did cleaned and oiled the chain with this)
- I have zero leakage past grease lubed bearings (I honestly put in quite a lot) and it run like a beauty, no more slipping that used to plague it in 1st and 2nd gear
- For best adjustment either follow SA advice and line up red mark or, simply put in 1st gear and adjust chain to be just tight (no play)… or just play around, they are quite finicky compared to 3 speeds
- Old bike stood for a long time or weathered + hub stiff = squirt in gt85 (take out indicator chain to the oil will go to the internals). This will loosen up the old dry grease
- This worked to stop some slipping, but really it needed a rebuild. Watch out though, online Youtubers make it look easy, and it is once you’ve done one, but not the first.
- Also, make sure you leave quite a lot bearing play in the drive side. Counter intuitive but very important! Download the sturmey rebuild instructions, there’s lots online.
- Most people don’t oil the hubs regularly to they run dry and damaged: people will then blame us
- Most people don’t have SAE20 in their can and/or have no clue what SAE20 even means – this is not the 1950s when men were proper men! 😊
- So what’s worse? A combination of too thin oil and/or no oil in their hubs, or fill them with semi-fluid grease that will last a couple of decades…
- Minimum: Squirt in oil through indicator chain hole to loosen them up
- Ideally: Rebuild, flush out grease, re lube using SAE20 or SAE30 oil (not cycle oil or squirty oil)
