Decided to strip down the old MTB to give it a service. The bottem head tube bearing was full of gunk instead of clean grease. The front wheel was kicking up grit and dust and straight into the bearing as it was slighty open to the air (you can see the ball bearings)
Fitted mudguards after renewing the grease. Problem solved.
After a Google search on the subject, should of read Sheldon Browns Site a long time ago
as the subject is covered there. Sheldon calls them fenders.
It appears the bottem bearing normally fails first
