Primal Scream
Get your rocks off
- On the road to hell
And a lot less likely to leave you with sore feet cause by pressure on soft soles.Stiffer soles. Better power transmission from leg to forefoot.
Mini clips are like a small cage that bolts to the front of your pedal which your feet slip into. Its the alternative to toe clips and straps.What are miniclips? I use knackered trainers and ondinary pedals which I know are not brill .. have to use your ankles a lot to keep feet on pedals, but I'm not ready to attach my feet to pedals yet...too steep a learning curve.
hi katekWhat are miniclips? I use knackered trainers and ondinary pedals which I know are not brill .. have to use your ankles a lot to keep feet on pedals, but I'm not ready to attach my feet to pedals yet...too steep a learning curve.
Stiffer soles are the main advantage but another spurious advantage may be that they keep your laces out of the pedals.
Thanks MickL, sounds interesting. I quite like the idea of something that gets me used to considering my feet when I stop.
