Noisy new freewheel
rh100
I know the real solution to this is buy a better freewheel, but.....
I recently replaced a 7 speed freewheel on a trek 7.1 I'm putting up for sale, I now have all the gears shifting beautifully but there is a dry, almost but not quite grinding noise coming from the freewheel when it is freewheeling but not when turning the cranks.
Ive re oiled it, but not much different, and I don't think it's the hub.
I've checked the spoke guard is not rubbing against the inside of the cogs.
Is this normal for a new freewheel? Is it likely to wear off or shall I pull it off and get a better one? Not really happy selling the bike with a noise like that on it.
Thanks for any advice
PpPete
Chandler's Ford
Was it making a grinding noise before you put it on ?
Freewheels are supposed to have grease in, when you say you "oiled it" you might have been washing the grease out.
rh100
rh100
Thanks, No there was no grinding before. I didn't go ott with the oil, not enough to wash any grease out.
rh100
rh100
<br />Is it possible the lockring is loose? Is there a lot of free play in the freewheel bearing?<br />
<br /><br /><br />
No lockring as it's a freewheel, rather than a cassette. Doesnt seem to be any play either
tyred
Ireland
There is a lockring with two small indents for a pin spanner which holds the bearing and freewheel mechanism together. It has a left hand thread.
Angelfishsolo
A Velocipedian
<br /><br /><br />
I did wonder, but I can't get the bugger off now to give it another clean.
Think I'll get another better quality one
You still will need to get the old one off :biggrin:
rh100
rh100
<br />There is a lockring with two small indents for a pin spanner which holds the bearing and freewheel mechanism together. It has a left hand thread.<br />
<br /><br /><br />
Are you thinking of the old sun tour type?
This one uses a tool similar to a normal cassette tool but unscrews the whole body from the hub, unless I'm missing something!
rh100
rh100
I know lolEither I finally get that vice I was given bolted to a bench, or I buy a long bar to lever the spanner, or admit defeat and head for the friendly lbs :smile:
tyred
Ireland
<br /><br /><br />
I'm talking about the bearing race/lockring which holds the body of the freewheel together. If you unscrew it completely, a billion tiny bearings and some pawls and springs will drop out and you will have great fun trying to re-assemble. I have seen freewheels (mostly cheapo BMX SS ones admittedly) which had the bearings too loose and were noisey. Tightening it made a big difference.
rh100
rh100
Ah right ok, just looked it up and I see what you mean.I'll have a look tonight and see if my pin spanner will fit, cheers
