I think my headset (threadless Aheadset) needs servicing but not sure.
I have been getting a lot of "cracking" sounds coming from my handlebar area recently, mainly when standing and putting the power down.
I've recently changed the handles from flat to drops but I had the problem before that, but it's since got a lot worse.
I first thought it might be the new adjustable stem, but I've swapped it over for a normal one and it didn't make any difference.
So I've been making sure all the bolts are tight, handle bar clamp, steerer clamp and adjusting bolt make very little difference.
But I found that if I tighten the top bolt it gets better. But I'm worried that i've had to tighten it too much.
I tightened it as much as I could last night and it was fine for a few miles but then started again. This morning wasn't too bad but I was taking it easy.
From what I've read it shouldn't be this tight. It has never been serviced since I got it 18 months ago, and it was an old model (Bianchi via nirone 06) so would have been sitting around for a while in Evans warehouse.
When I took the top cap off (when changing the bars) there was a lot of dirt and grease around the inside, so I wiped it out.
Should I take it apart and re-grease it? How do I do this?
Do I need a new headset?
Do you have any other ideas?
Thanks
Thanks
. Fitted a new bung and problem gone
but it is the wrong size
