Hi All, let me just clarify the meaning behind my thread title..
My question on this occasion is has anybody experienced a cracking/pinging type noise from the rear wheel of their SS bike that doesn't seem to be the bearings? I have recently purchased a used Genesis Day One 10 and as a matter of course I stripped out and replaced most bearings as it was in a bit of a neglected state with mud in just about every tube and hole you could find. Anyway, all was well for a few rides and then noises started from the rear wheel so I repeated the bearing strip/grease process and again all was well for a few rides then it started again. One of the cups is a bit pitted but nothing excessive and there is no play when the cones are tightened and they run freely with no binding etc.. I am now wondering if it could be one or more of the following reasons instead and would appreciate your thoughts before spending on parts that I don't need to spend on.
(1) I fitted a Sturmey Archer Sprocket which is quite 'fat' and because they have raised areas on the face it required the use of a spacer/washer to avoid it hitting the frame drop-out. *Could the additional washer be causing a slight change to the chain line that I'm not spotting, or when the track nuts are tightened could it somehow prevent the sprocket from running freely when under load? The wheels spins easily and smooth when I let it freewheel though which makes me think it's not the bearings.
(2) I have noticed that the chain is 1/8" but the sprocket I put on is 3/32". *Would that cause a 'meshing' problem and possibly noise if they are not the same size?
(3) My chain tension was quite tight which I suppose would get worse when it passed through those natural 'tight spots' during each rotation. *Could an excessively tight chain put too much tension/strain on the sprocket when it's attempting to turn and then possible cause the noises I've mentioned?
Sorry for the lengthy post but I have a habit of trying to cover every detail which ends up in a waffling ramble
Edit Quote Multi
Edit Quote Multi
