woodbine
- Bristol, UK
My 25 yesr old British Eagle MTB has been in storage for the last 20 years. I am putting the old girl back on the road. I have noticed that if the rear wheel is off the ground, and I pedal to get the rear wheel spinning, them let the wheel freewheel - there is a loudish roaring rumble from the rear hub area. It's worst with the chain on the smallest cog, and shifting the chain inboard to the larger gears sees the noise decrease quite a bit.As the noise happens only when freewheeling, I'm assuming its from the freehub - would this be correct?
One thing that may possibly have caused a problem is when I cleaned the dried on oily crud from the rear hub, gears, derailleur, etc. I used a paint brush and petrol - but was careful to lean the bike over to avoid as much dirt being washed from the petrol treatment and following wash off with water into the workings. Is it possible that some dirt has found it's way into the freehub? Can the actual freehub be dismantled, or is it a sealed unit?
Although the bike is old, it hasn't really done a big mileage, so I'm hoping the situation is salvageable. Thanks in advance for any advice.
