Decided to keep it..i will change the frame instead
Levo-Lon Guru 7 May 2015 #1 Decided to keep it..i will change the frame instead Last edited: 8 May 2015
OP OP Levo-Lon Guru 8 May 2015 #3 Rooster1 said: 7.9kg weight - impressive! Click to expand... you can build them to that weight if you fit high end parts. this tiagra model with cages and pump puter and padals is around 9.1kg
