Hi, I got a new bike with a Shimano SG-C6001-8D Nexus 8spd hub.
I researched how to disconnect the gear cable so I could remove the wheels and switch to Schwalbe Marathon Plus tyres; use an Allen key to turn the pulley, pop out the cable nut, disconnect outer casing. That went fine and I put the wheel back on.
But after reconnecting the gear cable, I've lost gears 7 and 8 and the two yellow dots are nearly aligned in 2nd gear, not 4th.
The Alien key port in the pulley is at 8 o'clock, not 9am, so I know it hasn't pulled the cable around the pulley enough. I've tried turning the pulley further away when putting the wheel back on and reconnecting it but it's made no difference.
While I'm pretty sure I tested clicking through all 8 gears and it was fine before my intervention, I can't swear on that.
Any ideas would be appreciated!
