Agree with @si_c 28s or 32s on bikes now. Had Schwalbe Duranos on for couple of years, zero punctures. Just bought Conti GP5000 28s going on this weekend, suspect they will be good as well.I'd wait until the current ones are worn out, but if they fit go for it. If happy with the current tires on then just size up.
Slight increase in comfort, and a bit more grip in inclement weather.
Edit: I have 28s on all my road bikes and wouldn't go smaller.
Just had the bike in for a service and we checked the clearance for 28mm, quite close but they will be okDo you have clearance for 28s?
I’ve got 28mm Vitoria Open Pave on my new to me Genesis Eq which are rather nice and make a cool Whooshy noise on good road surfaces
Conti GP5000 get good feedback, but not cheap nor the greatest puncture resistance if that’s important
No chance with mudguards thenJust had the bike in for a service and we checked the clearance for 28mm, quite close but they will be ok
Came with Continental Ultra sports on and had no problems so far, should last a bit longer yet. By the way how many miles should get out of a set of tyres ? given i usually do around between 60-100 miles/wk on normal roads
As I am on the subject....some advice please. New Eastons are 'tubeless ready'. Assume I take the plastic layer out, pop on rim tape and I am away. Thought I would ask before cocking something up![]()
Thanks, i am using tubes as tyres not tubeless type, it all seems more complicated than it used to beYup, they come with valves installed and sealed rims don't they? Just need a bottle of sealant and you're good to go.
I bought a charge cannister when I switched to tubeless, to help with the initial seating of the beads onto the rims, but it's not really been necessary - a track pump and dry-run, then inject the sealant through the valve, spin the wheel a few times on each side to spread the sealant and off you go.
