Hi guys, new to the forum. Hoping to share advice as well as get some valuable advice. Some I hope I will gain now.
I have fitted a new derailleur cable. Moved my chain to the highest gear (small cog) and shifter to highest setting, threaded it back through and tightened cable at hand tightness and then gone up and down the set to test the shifting. This is where I am getting the problem.
I am getting inconsistent shifting eg. delay in shift up and down, shifting two gears at once and not moving at all then moving two gears on the next switch. I have tightened the barrel adjuster and it is still the same but also its impossible to get into gear 1 as that gear is too stiff to move. Gear 2 is tight and when i shift up to 3, the tension released from the trigger is enough to hurt your finger.
I have rode bikes for years but always been apprehensive about repairs because the usual ending scenario is my taking it to a bike shop, showing them the mess i have made to fix it and then paying for more parts to get it sorted.
