New pump
TimP
I have a topeak road morph (for about a year now) it's worked well on occasions when I've needed it with no issues about passing 100psi. Equally it gets used with the MTB, where it can be a bit of a chore as the narrow bore means that it takes a while to get enough air into a fat tyre. The guage is a bit vague and you will want to look carefully at it to figure out how to read it.
It comes with a two bolt mount which prevents attachment of a bottle cage.
So, good at pumping, the hose arrangement means you are less likely to rip valves off, and the guage whilst vague means you can stop with the constant should I just put a few more strokes in.
